Vibration when first let clutch out....then goes a
Koty
05-20-2006 19:34:33
I have a 99 that has a vibration when I first let the clutch out in any gear. Once under motion it goes away. Not sure if it"s clutch or tranny..any ideas?
Kruse
05-20-2006 21:09:32
 Re: Vibration when first let clutch out....then go in reply to Koty, 05-20-2006 19:34:33
This quite often appears when a clutch disc is replaced without surface grinding the flywheel. What"s the history of your clutch plate, the pressure plate and the flywheel?
Koty
05-21-2006 12:34:31
 Re: Vibration when first let clutch out....then go in reply to Kruse, 05-20-2006 21:09:32
I'm not sure of the history, I've only had the tractor for a year. I think maybe I should take the cover off an try to inpect the clutch and go from there.
WFE 2
05-20-2006 20:35:43
There are a number of possibilities, but if it were my tractor, I'd first look at clutch based on what you say. A leaky rear main seal can impregnate the clutch facing with oil and make the clutch jerky or vibrate during engagement. Does the rear main leak? Could be pilot bearing/bushing bad, broken pressure plate springs, warped pressure plate or flywheel, etc.
