88 Oliver Standard - Add Oil in Transmission
Kevin B64752
05-18-2006 17:22:10
After draining transmission fluid, how do you refill it?
bradk
05-18-2006 17:40:38
 Re: 88 Oliver Standard - Add Oil in Transmission in reply to Kevin B64752, 05-18-2006 17:22:10
To the right and ahead of the shifter base.~brad
Kevin B64752
05-18-2006 17:54:17
 Re: 88 Oliver Standard - Add Oil in Transmission in reply to bradk, 05-18-2006 17:40:38
Is there a plug by the oil filter for the hydraulic system that fills the transmission? Is the transmission and differential all in one?
bradk
05-18-2006 18:07:07
 Re: 88 Oliver Standard - Add Oil in Transmission in reply to Kevin B64752, 05-18-2006 17:54:17
Yes,the plug is under the hydraulic filter housing.About 1 1/4" in dia.Trans & diff are together-fill as one.~brad
Kevin B64752
05-19-2006 18:14:57
 Re: 88 Oliver Standard - Add Oil in Transmission in reply to bradk, 05-18-2006 18:07:07
Thanks for the help! that is exactly what I needed.
