Oliver 77 disk brakes
Don Hopf
05-17-2006 11:01:14
Would like to rebuild the disc brakes on a Oliver 77. How many replacable disc plates are used?
Don Hopf
05-20-2006 17:05:31
 Re: Oliver 77 disk brakes in reply to Don Hopf, 05-17-2006 11:01:14
Thanks for the answer. The 77 brakes will need to adjusted or replaced. Just about hitting the back of the hydraulic pump. Just have to talk Dad into writing out a check.
Just got done converting her to 12 volt alternator. Should"ve done it years ago. It always started right away with 6 volts if the battery was fully charged. Now just tap the the starter switch and it running.
Mike in MI
05-17-2006 16:35:47
Don,
There two sets disc to each side. Just a thought If your rebuilding thr brakes I would replace the three Extention springs on each side also.
I can remember what they cost now been awhile since I done mine. I found mine where getting stretched from the heat.
Mike
1755
05-22-2006 15:42:14
 Re: Oliver 77 disk brakes in reply to Mike in MI, 05-17-2006 16:35:47
Just did one $35 covered new disks and springs for one side
