Turning Fuel Pumps On Pekins
BugsBunny
05-16-2006 18:59:37
I have an 1850 oliver with a perkins and i put a turbo on it and i tractor pull with it and i would like some more smoke but i do not have the money to pay some one to turn it up and i would like some help or some one to email me a copy on how to turn it up and any help would be nice
thank you for your help
Marc Smothers
05-18-2006 16:24:07
 Re: Turning Fuel Pumps On Pekins in reply to BugsBunny, 05-16-2006 18:59:37
I have my pump turned up as well as bigger injectors in my 2-105 and have been using that way for over 2 years farming and pulling... No problems yet, just put in a pyrometer and keep an eye on it. I plow all day with it at 1100 degrees. If the motor is tight I don't see why you would have a problem with the crank... Good luck, Marc
landlord7012
05-17-2006 17:15:03
 Re: warning:going for broke in reply to BugsBunny, 05-16-2006 18:59:37
Just advice: Brother-in-law has White with a Perkins (no turbo). He turned up the pump and twisted the crank (went for broke - get it?) If you don't have $ for turning up pump you don't have $ for crank either!
ll
Jim Pollock
05-17-2006 14:54:30
I see that no one answered your question so I will try to help you out.
I am not very familiar with the perkins engine but I do know that it uses the same kind of injection pump as some David Brown tractors. To turn up the David Browns, you take off the window on the side of the pump. All the fuel will drain out and you should see 2 small bolt heads through this hole. You wiil need to turn the engine over by hand until you can get at one of the bolts and loosen it. Then turn over the engine some more until you can get at the other one. Now with them loose you should be able to turn the ring slightly that these bolts thread into. One way will increase the fuel and the other will decrease the fuel. I can't remember which is which.
After you turn the ring, you will have to tighten both bolts and replace the window. Then you will have to bleed the pump before the engine will start.
I hope this helps.
bug bunny
05-27-2006 19:48:27
 Re: Turning Fuel Pumps On Pekins in reply to Jim Pollock, 05-17-2006 14:54:30
Well all I now is that the fuel lines go up or on the top of the fuel pump and it is turned 25% up all ready and not enough smoke and it does not power out on the track it spins out but would like to have more smoke because when you take off there is a little smoke then it clears up and it needs more smoke
