front end on oliver 1850
tim nedder
05-16-2006 17:30:32
does any one have suggestions on how to losen up the wide front so i can move it in for narrow rows to spray ??? tried: got tightening bolts lose and pin out but can't get it to budge
dave schrock
05-17-2006 16:08:49
 Re: front end on oliver 1850 in reply to tim nedder, 05-16-2006 17:30:32
I had the same problem 25 yrs ago and we got everything loose like you have and blocked the front off the ground and hooked a tractor on each side snugged them up and started heating with large blow torches not cutting torch. When hot we put both tractors in lo gear and let them spin while we took sledges and beat on the chains. It came apart ,we then wire brushed everything , antiseezed and put it back. Have fun be CAREFUL. We had to come out before going in
