Oliver 55 Winter oil ,tranny fluid winter plug in.????????????
Stewart
10-30-1999 22:22:39
What can I use for engine oil in winter and tranny. Anyone using a block heater, what type .Thanks in advance Stewart
Aaron
10-31-1999 09:14:55
 Re: Oliver 55 Winter oil ,tranny fluid winter plug in.???????????? in reply to Stewart, 10-30-1999 22:22:39
It all depends on how cold it gets where you are. The tranny fluid should be fine in almost any weather. I'm not familair with Olivers, so this is all general information. The engine oil should be 10-30 or straight 10, depending on how cold it gets. We run block heaters on all our tractors. They are the kind that go in the soft plugs in the side of the block. They work very well and all our tractors plugged in start like it was sunny and 90 out. Aaron
Paul Stanley
10-31-1999 11:37:11
 Re: Re: Oliver 55 Winter oil ,tranny fluid winter plug in.???????????? in reply to Aaron, 10-31-1999 09:14:55
I have a Super55 diesel, and I use an inline waterheater. You splice it into the lower rad hose and it works like a charm. Mine isn't stock, but it is similar to the ones Oliver used.
