Steering u-joint
oliver88robb
05-15-2006 08:23:50
I have a 1948 88 Standard that needs a steering shaft u-joint. Where do I go to get one? What part # is it? It is the joint on the left side next to the frame rail. Thanks Robb
Steve Metcalfe
05-16-2006 06:19:21
 Re: Steering u-joint in reply to oliver88robb, 05-15-2006 08:23:50
Maibach's has them. 1-800-808-9934
B A Star
05-15-2006 19:08:45
If you have a truck parts company like Inland Truck Parts Comapany, Trucks use the same size u-joints on the driveshaft to the pump for the hydraulics on the dump box. They should be able to fix you up. They may be able to supply you with a cross kit to renew your present joint.
