Engine Stand
jimfitzgerald-ia
05-14-2006 13:57:33
I will be overhauling a Super 88 engine soon and I was wondering what anyone uses for an engine stand. Any suggestions, design ideas, pictures, ect is appreciated.
WFE 2
05-15-2006 05:56:21
 Re: Engine Stand in reply to jimfitzgerald-ia, 05-14-2006 13:57:33
You can get as elaborate as you like. A regular automotive stand will work as long as you attach it properly. However, on these engines, I would normally just do the following: Remove as much as you can while the motor is in the tractor (make it as light as possible). Once you have the motor out and suspended with your cherry picker, skid loader, etc., use the bathtub frame to support the engine. It is just the right working height, and you can use a piece of plywood and wood blocks at the cylinder head side to lay the block down on its side. Once the crankshaft is out, the block becomes light enough to move around by hand by yourself or two guys. I find it a little easier to do the initial stages of reassembly with the block horizontal.
davpal
05-15-2006 00:23:48
My dad built a heavy duty engine stand for us that simply uses a piece of plate steel and we have about ten different sets of bellhousings drilled in it to match many different engines. I saw a really neat idea where a guy adapted a bellhousing from his tractor to an axle on the back of his tractor and mounted the tractor motor to it. If he wanted to turn the engine over he just rolled the tractor ahead or back. It was real slick. He said the tractor was sitting there anyway so he made use of it. And the axle was plenty beefy to hold the weight. I think it was a case tractor. Just an idea.
george md
05-14-2006 22:54:46
third party image
Jim, I have a waukesha 190 GLB on the stand now , it's for a michigan 75 A loader but is the same engine as the 88 gas . That stand has also had JD 466 , and case 501 engines on it . I built a big stand to use for the cummins 855 engines , but after using it a few times I found that it is easier to build them on a box . There are some more pictures on the link.
george
