engine trouble with 70
matt theissen
05-11-2006 15:57:04
I'm having trouble with a newly restored engine in a 70 "row crop". The engine appears to only run on 3 and 4 cylinders . Ignition appears to be good but it seems outer cylinders will not pull any fuel. Everything obvious has been checked including compression which is all around 100#.
Does anyone have a name and number of any oliver restoration/engine experts that I can contact?
WFE 2
05-11-2006 18:05:03
 Re: engine trouble with 70 in reply to matt theissen, 05-11-2006 15:57:04
You have spark at all 6 plugs at equal strength and at the right time? Next, based on your observations, I would check for a leak in the intake system, possibly at manifold or carb that is allowing tractor to suck air from outside rather than through the intake and carb.
