OLIVER 88 STARTER SWITCH
KJF
05-08-2006 22:11:52
Having trouble getting an Oliver 88 started! Sat inside since last August and put new gas in it over the weekend started fine! Shut it off and started it up a half dozen times over a 3 hour period. Shut it off for lunch and went to start it back up but it wouldn't go. Push button seemed to not be working, jumper cables from battery to starter and nothing, put in spare battery and tried push button starter and nothing. Jumper cables from battry directly to starter and it fired right up! Used it for another hour and it ran out of gas, added more gas, jumper cable from battery to starter and battery was dead! Any idea what is causing this! Any help is appreciated! Thanks in advance!
old
05-09-2006 08:30:40
 Re: OLIVER 88 STARTER SWITCH in reply to KJF, 05-08-2006 22:11:52
Sounds like you need to clean all connection from the battery to the starter/gound. Sounds like dirty/loose cables and or bad cables
