Oliver 1800A Checkerbboard WideFront Wobbling
MOSteve
05-06-2006 16:42:43
I've recently put larger front tires and wheels on my 1800A wide-front. Last week I plowed about 4 acres with no problems. I put the tractor away in the barn and didn't notice any problems. Yesterday, I took the tractor out and noticed that my front left tire is wobbling pretty good. Any ideas on what my problem could be? I'm relatively new to this tractor mechanic stuff and it's always helpful to get advice from the Oliver experts before I tackle a problem, Thank you.
Jeff Oliver
05-07-2006 04:40:29
 Re: Oliver 1800A Checkerbboard WideFront Wobbling in reply to MOSteve, 05-06-2006 16:42:43
First thing, check the jug nuts ( I know this from experience). If they are tight, get on it and move it and watch to see where it wobbles at. If the entire spindleand arm is moving check the tie rod, if it is just the wheel take the grease cap off od the center and tighten the nut there.
Max Edlin
05-06-2006 18:56:50
Possibly a bad tie rod end since you said it was only the left wheel wobbling.
Olivergreen
05-06-2006 16:53:55
If you havn't had any previous problums, check lug nuts. might check tire for slipped belts.
