hydra power 1655
crystal allis
05-05-2006 18:23:11
hi i was wondering if the hydra -power drive unit from a 1800 would fit in a 1655 i am new to olivers thanks
dwm7
05-07-2006 11:47:31
 Re: hydra power 1655 in reply to crystal allis, 05-05-2006 18:23:11
One detail you need to know is the difference between the 3-speed Over/Under Hydraul Shift and the 2-speed Hydra-Power drive. Folks talk about these and get them confused, particularly with confusing over and direct on a Hydra Power. O/U is just that, an overdrive and underdrive from the standard direct drive. The Hydra-Power is underdrive only along with direct drive. Your 1655 should have the 3-speed O/U, I don't know of any that had only the Hydra-Power. I'm not sure if units from the larger tractors will work, but do know the bell housing would be larger to clear the clutch. Good luck.
