Engine Piston-Sleeve Set for Oliver 60 ??????????
Larrys2
05-04-2006 06:26:22
Can anyone give me help on parts avilablity on engine ,and clutch , and other needed general part,and where to find them. Thanks..... ..
Ron Grother
05-05-2006 03:00:03
 Re: Engine Piston-Sleeve Set for Oliver 60 ?????? in reply to Larrys2, 05-04-2006 06:26:22
I have good used parts email me with your needs.
Tip
05-04-2006 08:46:55
The good news is that more and more parts are becoming available, but you still can't get everything.
No one makes a kit for sleeves and pistons. Rings and bearings are available. If your sleeves are very worn, you can bore them out and install a larger piston - John Schweibert has the information on this.
Pretty much everything else, including manifolds are available from Korves Brothers or Farmersville Equipment, both of whom are excellent folks to deal with. I am just finishing a 60 rebuild and purchased parts from both folks.
Regards, Tip
