Well, from the beginning: 0. Been using this tractor for field work for the last two years. My biggest machine, she's done a fine job up until about a week ago.1. Pump worked great, but a hose leaked a little. I replaced the hose, and the hydraulics quit. I still get great volume on the lines going to the oil cooler on the front of the tractor, but nothing else seems to function as it should--except the PTO, which on this tractor I believe is hydraulically controlled (though there is another pump for some other systems.) But on the oil-cooler lines, it pumps nice volume and pressure--that's how I've drained the 7 gallons out to service the tractor. 7 gallons out in about a minute or two, and it sprays like we have pressure, it doesn't 'glug' out like it's falling by gravity. 2. Oil is full. Checked that several times. Bled the system for air too, though I notice the oil itself looks kinda light brown like peanut oil. 3. Numbers on the pump label are arranged thusly (though nothing is well labeled, so it's hard to guess what means what):
Vicker 432148 A/91/0 M PVB15 LSGW 21 C 10 219
And on the pump casting is 397704 And on the regulator port is 241567C4. Since the paint doesn't match, I also suspect it's not the original pump. I'm not sure what sort of pump really should be on there. My best guess is that the regulator on the pump isn't doing quite what it should. At this point, I have an impressive lawn ornament. Without proper hydraulics, it's very difficult to steer. I wouldn't dream of taking it to the field in this condition, even if the remotes did work (they don't.)
