More hydraulic problems, 4-150
Dan-IA
05-01-2006 13:33:52
Well I bled it out for air, ran it a bit, let it sit, bled it some more... And the hydraulics are still not what they should be. The pump on the rear-end is getting warm fast. PTO works, but other than that the hydraulics don't seem to do much of anything at all. It's like that valve assembly right under the pump isn't letting any oil through. Steers like the engine is off!
I know the pump is running, because if I open the bleeder with the engine running, it plainly sucks air (the pipes start shaking.)
Best I can figure is that I've still got air in it, somewhere. What now? Run it until it straightens itself out? Or do I have to bleed it a couple dozen times?
Thanks
J Schwiebert
05-02-2006 03:50:30
 Re: More hydraulic problems, 4-150 in reply to Dan-IA, 05-01-2006 13:33:52
I can think of a couple of things to have you check. Do you have a pressure gauge that goes to say 3000 psi to start with. Send me a phone number. If it rains I should be home tonight. J.
Olivergreen
05-01-2006 14:48:31
I,m having the same trouble with an 1855. Steering & brakes work fine. 3point goes up real slow. Remote valveswon't work ether.
