OLIVER 77 RC IGNITION PROBLEM
Wallace Hunsake
10-25-1999 20:34:51
My brother and I own a 77RC that will run only if either end of the coil wire is held away from the coil (or distributor cap) about 1/4 inch. If you insert the wire completely, it dies. We have tried differnt coil, coil wire, distributor cap, rotor, points, and condenser. The plugs are correct. We would appreciate any suggestions.
Male Gayle
11-08-1999 15:43:33
 Re: OLIVER 77 RC IGNITION PROBLEM in reply to Wallace Hunsaker, 10-25-1999 20:34:51
Make sure the spark plugs are not the Champion brand. They will not fire at the least bit of oil fouling. Go for AC Delco or Motorcraft plugs.
Bob M
10-26-1999 04:27:23
Sounds like your spark plugs are partially fouled. Install a new set of plugs - and recommend using the next higher heat range if available.
