Gear Growl In 550
Jason Barnes
04-28-2006 06:36:43
Noticed a Gear Growl under seat of my Oliver 550 recently Wondering if this could serious and need to tear down Thanks
T. Evans
04-28-2006 16:31:37
 Re: Gear Growl In 550 in reply to Jason Barnes, 04-28-2006 06:36:43
Hello, I have several questions regarding "gear growl"
I have an Oliver 1450 diesel, and it growls when moving.
Could this be from the nuts on the pinion shaft loosining up?
Is this even possible on a 1450?
How hard is it to tighten them back up?
How would I go about tightening them up? Or even
What is a pinion nut? where is it found? and How do I access it?
If it were the pinion nuts that loosened up causing this, would it hurt the tractor to tow it home? Its about 2mi away from my house.
J. Schwiebert
04-30-2006 15:41:59
 Re: Gear Growl In 550 in reply to T. Evans, 04-28-2006 16:31:37
You are dealing with A Fiat built unit. I sent you 2 e-mails not let me know if you did not receive them and if not we will find a Plan "B". J.
T. Evans
05-01-2006 12:13:38
 Re: Gear Growl In 550 in reply to J. Schwiebert, 04-30-2006 15:41:59
Hello, I seem to be having problems with my email, try emailing me using the address used for this post, its my dads email, so perhaps it'll work a bit better. thanks for trying to help out, and try it again, the email used in this post should work, so I guess thats all I can say.
Thanks.
T. Evans
05-07-2006 17:27:39
 Re: Gear Growl In 550 in reply to T. Evans, 05-01-2006 12:13:38
I've found the problem, the shaft that comes from the transmission (don't know the name) that connects to the diff via a gear, has a BAD bearing, bad as in rollers flopping around loose in the bearing race. to remove the bearing I believe requires removal of the diff (correct me if I'm wrong) and... I'm not sure how to do that,
We're going to buy a shop manual, but if anyone has suggestions we would appreciate them. it looks like you need to remove the whole tire/wheel/driveshaft assembly and then pull the diff out through the top. is that the required procedure for removing the diff, or is there a easier way to replace the bearing??
also does anyone know a place that might have these bearings available?? also I need some little "clips" for the pto lever, they run in a little slot on the sliding engager thing. one side is rounded and fits into the little slot on the engager, the other fits into the actual lever part.
Thanks,
Tom
Lee W
04-28-2006 07:14:57
The double nuts on the pinon shaft could have come loose, I am working on one now that it happened too.
