decal placement, any suggestions?
newter haven
04-25-2006 18:32:27
I've got new decals for the 110 was wondering about spraying water on the sheet metal to place them and then squeegee them off?, has anyone done such a thing? They're about five foot long or so they could be a bear to get into place. Any ideas are greatly appreciated! Thanks.
Super 55
04-25-2006 20:17:33
 Re: decal placement, any suggestions? in reply to newter haven, 04-25-2006 18:32:27
Check out page 198-199 of the Antique Tractor Bible by Spnecer Yost. Email me if you like.
B A Star
04-25-2006 20:13:14
Yes you can use water to install decals. Better yet mix in some liquid soap in the water. Wet down the surface where you are going to install them. Now remove the backing on the decals and dip them into the solution just before you install them. You can now move them if you don't get them in the exact place you want. You can squeeze the solution out from under the decal working from the center out. You will have to hold them in position as you start to squeeze. That's the way we did the combine decals and you know how long they were.
newter haven
04-26-2006 18:39:50
 Re: decal placement, any suggestions? in reply to B A Star, 04-25-2006 20:13:14
If that soap and water idea worked for you that's what I'll do, also. What about the outside backing will the water solution affect it in any way? I guess after pressing the excess water out that can be removed without much trouble or should I let it dry for awhile? Sounds like a good idea, thanks so much!
