need engine for 1850 cockshutt
out west
04-23-2006 19:34:27
Does anyone know what 354 engines out of the massey combines will fit. I was told the 510 and 750s would work.If anyone could help me it would be much apprieciated.
out west
04-29-2006 22:08:28
 Re: need engine for 1850 cockshutt in reply to out west, 04-23-2006 19:34:27
thanks for the info this realy helps. now to track down an engine.
Chris IN
04-28-2006 16:02:58
I thought that the Perkins 372 was in the Massey 750? Am I wrong???
Chris Willy
04-24-2006 08:55:37
out west - I am currently as we speak putting a 354 Perkins out of 750 Massey combine in an 1850 Oliver. it is the same series of motor however there are some differences. The front timing cover, water pump, bell housing, and oil pan need to be switched. The 354 Perkins I got out of a 750 Massey has a turbo charger on it. This will cause a few modifications for me in routing the exhaust and intake tubes under the hood again. Overall it is a pretty easy swap I think, if your willing to do some tear down and build up. Hope this helps. Let me know if you have any more questions.
Chris
