550 3 pt hitch
Jeff from iowa
04-22-2006 15:20:00
Sorry, I know this was covered in the past, and I did check the archives, But what does a guy need to do about hiccuping in the three point hitch under load? Is it an o-ring thing? Is it bad to leave go this way? It is a '61 550 diesel. Thanks-Jeff
J Schwiebert
04-22-2006 17:13:13
 Re: 550 3 pt hitch in reply to Jeff from iowa, 04-22-2006 15:20:00
You have an internal leak and the double feed back linkage is trying to compensate for it. You will need to take the unit off and disassemble (remove the cylinder & valve) from the unit. There is a procedure on how to check it with the aid of a shop press. Questions?
Jeff from iowa
04-22-2006 15:29:12
By the way, It also was leaking a little oil where the spline deal comes off the tractor for the lift arms. I had a 3pt scraper on.
