Is there any way to tap in to the on board hyds
old
04-21-2006 17:48:51
On a 770. I woroked on one today that has a loader and one of the hyd levers is wired up so the hyds are running all the time to one side of the system. Can you tap in some how so it would not be so hard on the pump etc?? I sure hate seing things done that way, there has to be away but how?? Thanks
jim1650
04-23-2006 04:22:27
 Re: Is there any way to tap in to the on board hyd in reply to old, 04-21-2006 17:48:51
that sounds like a great idea as i have a 770 also and would like to know how to do that thank u jim
J Schwiebert
04-23-2006 05:40:13
 Re: Is there any way to tap in to the on board hyd in reply to jim1650, 04-23-2006 04:22:27
How big a hurry are you? Starting this fall in the hpoca news letter there will be a series of tech articles on the older hydraulic units. This will be covered then. If you have questions now send me a pm on the hpoca site. Questions?
Mike (WA)
04-22-2006 08:51:46
You need to tap into the "power beyond" feature, if it has one. On my 1550, one of the pipe plugs (near the front of the housing, as I recall) had a smaller pipe-threaded hole inside. You put a 3/8 pipe plug into that inside hole, and voila, you've got a live hydraulic port. Run a hose from that port through the loader valve, then back to a return port. The return will just be a plug down on the side of the housing to return the oil to the reservoir.
J Schwiebert
04-22-2006 09:10:21
 Re: Is there any way to tap in to the on board hyd in reply to Mike (WA), 04-22-2006 08:51:46
He is talking 770 and yes they have a power beyond feature. I sent him an e-mail. J.
