oliver 550 gas rear wheel weights/ front weights
j.r. renfro
04-21-2006 15:29:38
I'm the proud owner of a 1964 Oliver 550 and need some info on what rear wheel weights and how many to mount on it. It has 13.6X28 rear wheels. Also I'm needing info on front weights and how many to mount. The tractor has the power to lift and transport round bales but can't hardly keep the front end on the ground.
1755
04-25-2006 14:36:22
 Re: oliver 550 gas rear wheel weights/ front weigh in reply to j.r. renfro, 04-21-2006 15:29:38
If you have the power ajust wheels you will have to look for the whaights with cutouts for the power ajust brackets there are several manufacturs that used the same setup If you dont have power ajust wheels the regular oliver whaights or the ones for power ajust wheels will work
