2255 hydraulics not holding
OliverGuy
04-20-2006 14:18:24
Anyone have an idea on what to do first if one outlet won"t hold? (other one is OK) If I lift an implement and then return the lever to center the implement drops. I"m guessing this could be a big $ job of valve changing, etc. I like this tractor, but boy it can suck the money and it"s hard to find parts and people who know about them. However, I do love valve covers hanging out the side and the CAT growl out a straight pipe.
OliverGuy
04-24-2006 07:18:09
 Re: 2255 hydraulics not holding in reply to OliverGuy, 04-20-2006 14:18:24
Thanks for the info. I'll take what you both said and talk with another guys who does some of the mechanic work for me. For whatever reason, it didn't do it all the time when I used this weekend. I pulled a 24' field cult. and it seemed to work fine (except the cab AC wasn't cooperating, oh well). She looks a little different in the field around here, too many other green tractors working around here. Any other info you had Mr. Schwiebert would be great. Thanks again.
Ken from Ia.
04-20-2006 21:41:35
I have a White 2-135 with the detent valve bodies that would lower it turned out to be a cracked O-ring on the thermal relief
J Schwiebert
04-20-2006 19:13:36
There is a plastic poppet that has to seat. I had a Moline man with a G1355 ask the same thing. The poppet becomes a pilot operated check valve and if it leaks the implement will drift down. I can make you a copy of a cut a way view of the valve that we received in service school when that system was new. I can do that next week. I also think the part number has changed on that part. I know a dealer that has or had them in stock when I checked this winter. Questions? J.
