snapping shear bolts on mower - 1850
mud
04-17-2006 05:58:41
Well, we hooked a new-to-us mower onto the 1850 and mowed some. After mowing 2 acres the shear bolt that connects the mower's primary shaft to the big gear box broke.
Put in a new bolt and snapped it like a tooth pick. The mower turns easily by hand. The pto on the tractor engages well.
The mower is a Deere 1518 flex-wing.
Thanks-
Mike
J. Schwiebert
04-17-2006 10:10:07
 Re: snapping shear bolts on mower - 1850 in reply to mud, 04-17-2006 05:58:41
Explain this a little better> Are there any threads in the area where it should shear? Fox choppers used to warn you about that problem and in both cases you are trying to start and object with a large momentum factor for lack of a better description. How far did you throttle the engine down when you engaged the PTO. Is this a 540 or 1000 RPM PTO? What size and grade is the shear bolt? J/
mud
04-17-2006 11:41:09
 Re: snapping shear bolts on mower - 1850 in reply to J. Schwiebert, 04-17-2006 10:10:07
It is 540 RPM.
I idled way down when I engaged the PTO.
The first time I started the mower I was in the field, and idling very low. We mowed for about 30 minutes just checking everything out. Varying gears and engine speed.
Mowed again in about 2 hours. Drove 400-500 yards and broke the shear bolt. It was grade 6 with no thread inside the castings on the two hubs .
The 2nd. bolt broke in a big hurry. Again, I engaged the PTO under a low idle. The bolt broke right away.
PTO clutch need adjusting?
You sure hit the nail on the head when you said that about a large momentum factor.
J. Schwiebert
04-18-2006 03:51:34
 Re: snapping shear bolts on mower - 1850 in reply to mud, 04-17-2006 11:41:09
What is a grade 6 bolt in your terms. What size is this bolt. I just thought of something. Find me on the hpoca form and send me a pm with your phone number. J.
mud
04-18-2006 11:33:29
 Re: snapping shear bolts on mower - 1850 in reply to J. Schwiebert, 04-18-2006 03:51:34
Hello J. Schwiebert
Got your reply too late. I will try to reach you on hpoca tonight. Thanks, Mike
