are 50 series fenders the same as 55 series
nickg
04-15-2006 05:51:39
I'm looking ofr a pair of fenders for my 1855 and was wondering if the 50 series fenders were the same?
1755
04-18-2006 15:32:58
 Re: are 50 series fenders the same as 55 series in reply to nickg, 04-15-2006 05:51:39
The part that the lights go in that is diferant dont that bolt in you might be abel to swap it with your origonal fenders unless you are swaping for fuel tank fenders or the other way
Princeton Bill
04-15-2006 18:55:37
They should work. The 50 series fenders will have a place for 2 lights in the fender light plate, whereas the 55s only have one light in the fender.
1750, 1850 and 1950 fenders should work. Don't know about the 2050 and 2150s. 1650 and 1550 fenders are smaller, but you can use pipes, washers, make brackets etc. to get them to work. The 1750 Special used 1650 fenders with a bracket to get them to mount on the tractor.
j meyer
04-15-2006 18:20:16
Hmm, I believe if you go from an 1850 to and 1855, yes they would be, but without the stripe, of course. I know the 16XX series is different to the 17XX and above machines.
