OLIVER 550 LEAK
Allen L
04-12-2006 11:27:08
My Oliver 550 leaks transmission fluid. It pours out the bottom plate where the adjustment for the PTO is located. Someone said the case may be broken but I see no cracks on the outside. I really want to get this rusty 550 back to life. Any comments as to the possible problem will be appreciated. thanks for your time.
jake1
04-15-2006 08:14:51
 Re: OLIVER 550 LEAK in reply to Allen L, 04-12-2006 11:27:08
A tool can be made using 2' black pipe and welding or brazing 2 tabs [3/8 w 1/8 thick and 1 1/4 long. This works like a charm. Using the hammer method it tears the nut and torque to re install. It's simple I could send a picture if needed.
Allen L
04-16-2006 17:43:09
 Re: OLIVER 550 LEAK in reply to jake1, 04-15-2006 08:14:51
Jake, thanks for the info. I sure would appreciate a picture of your tool as you described for the PTO on the 550.
Allen L
04-14-2006 15:18:59
Thank you for your response!
Awanabefarmer
04-13-2006 10:06:15
You�re leak is probably the seal behind the PTO clutch. As for the tool I do not know were to get one, the company that made them sold out and the new one does not make one. They do make one for a Ferguson they say will work, but its $120. If you�re careful you can use a punch and hammer. I would suggest the I&T manual.
Awanabefarmer
Max Edlin
04-12-2006 18:06:10
Neighbor had one with the same problem. We fixed it for him. Was a seal where the pto clutch pack is located. Requires breaking the tractor in half and one special tool to take the pto clutch out. A I&T manual shows how to do it. Hope this helps.
