Small job just got a lot bigger!
Paul Stanley
10-23-1999 15:44:47
Went to replace an oil seal on the bull pinion while doing a brake job and what did I see? The bearing right behind the pinion, in front of the bevel gear shaft was a collection of small ball bearings sitting outside the race.
Now I have the seat off, the transmission cover off and ready to take off the bull gear, and slide the axle out to get to the bevel gear. Not only that, when I drained out the oil, I saw a small woodriff key laying on the bottom. Wonder what that's from? This is like quicksand the harder I struggle, the deeper I go!
It's times like these I wish I hadn't torn down my garage until I was ready to build another in a hurry. Oh well, I repaired and replaced my Willys transmission when I lived in Ontario at -30�. That was in the driveway too! Now I'm in sunny British Columbia .....
Chris Losey
10-24-1999 08:02:28
 Re: Small job just got a lot bigger! in reply to Paul Stanley, 10-23-1999 15:44:47
Paul,
There is only 1 woodruff key inside the tranny that i can find. And guess where it is. On the front of the bevel pinion shaft. Also, hope that it isn't pieces of the thrust bearing for the bull pinion that you found. It tooks us a while to find a good set from a salvage yard. We couldn't find a new replacement. Everything else was easy to get. Hope this helps.
Chris
Paul Stanley
10-24-1999 17:41:33
 Re: Re: Small job just got a lot bigger! in reply to Chris Losey, 10-24-1999 08:02:28
Thanks for the tip. I looked it up in my parts book and its a 1/8 X 5/8 woodruff key. Wonder if it's off of the shaft. It looks like it holds a sleeve in place. I'll have to check it out while I have the top off.
John
10-23-1999 19:13:52
Just goes to show you never know what you will find until you open it.
highboyford
10-23-1999 17:45:42
Hey Paul I thought I was the only one to have this kind of luck.Well at least you get to learn where that key goes:}Maybe a factory worker threw that key in so if the tractor ever gets worked on the owner goes nuts trying to find out where it goes.
Paul Stanley
10-23-1999 22:51:12
 Re: Re: Small job just got a lot bigger! in reply to highboyford, 10-23-1999 17:45:42
you know I thought of that key not even belonging in there right away, but that might just be wishful thinking.
