Oliver 1800A Left Steering Arm
MOSteve
04-09-2006 18:01:30
I recently bought larger from tires and now the front left tie rod is rubbing on the tire. I've discovered that my sterring arm is bent slightly. Does anyone know where I can get one? I've tried to heat it up with my MAPP gas plumbers tourch and just can't get it hot enough to bend it. I'll try the AGCO dealer, but not sure if this is a part they'd still carry. Thank you.
J. Schwiebert
04-10-2006 04:32:14
 Re: Oliver 1800A Left Steering Arm in reply to MOSteve, 04-09-2006 18:01:30
Make sure you measure the length of the arm. Not all 1800A series tractors have original front ends as later ones also fit and it may have been installed later. The arm will also be used on other models. Questions?
MOSteve
04-10-2006 07:28:57
 Re: Oliver 1800A Left Steering Arm in reply to J. Schwiebert, 04-10-2006 04:32:14
Tahnks again Mr. Schweibert. I've called my AGCO dealer and we walked through the issue you brought up. He can get the part but it's $280.00. I think I'll try to find someone with an acetelene torch that will get the piece hot enough to bend.
ryan from WI
04-09-2006 20:02:56
Yes your Agco dealer should have it or can get it. They can get any part for all of the Agco heritage line.
