Cockshutt 30: Changing the front end
Dan-IA
04-08-2006 19:42:24
Here's my next puzzle. For my project, I will want to change the wide front end and put in a narrow one. Now, will I need into the gearbox itself (through the top), or maybe under it?
Because the hydraulic oil tank sits right on top of that, and if I need to remove the hydraulic tank to change the front end, then it'd be simpler to do that now while it's already out.
Or is all that I need to work with underneath the frame?
Irv Buttray
04-10-2006 06:29:32
 Re: Cockshutt 30: Changing the front end in reply to Dan-IA, 04-08-2006 19:42:24
Dan, if not changing gear box then remove hydraulic tank, remove cover from gear box, after unbolting 4 bolts that hold gear box to frontend mount undo clip in side box and drop complete front end from tractor. I find it easier in most cases to undo steering shaft at gear box, remove radiator, nose metal, hydraulic resevoir then remove front end with gear box attached. place gear box on new front and put it on as an assembly. You can asses situation your self and descide. email me if you want for additional onfo. Irv
