770 pto overhaul
j105
04-06-2006 18:25:29
My pto on my 62 770 got to where it would just start tuning whenever it wanted. I tore it apart and found the shaft splines were bad as well as the splines on the clutch disks. I replaced both and also the seals, springs and center plate. I used complete shim sets or so i think.(about 3/16" total) I got it back together today and I cant even pull the lever over center. Im stumped. do i need more shims? I did notice the new pto shaft was maybe 1/8" longer than the old,but had same number stamped on it. any help would be appreciated.
j105
04-07-2006 05:05:33
 Re: 770 pto overhaul in reply to j105 , 04-06-2006 18:25:29
thanks fellas, i'll get some more shims
B A Star
04-06-2006 22:33:37
The PTO engagement is adjusted properly when it requires 35 pounds pull just below the knob to snap it into engagement. To obtain the proper adjustment, add or remove shims in the clutch.
Mike in MI
04-06-2006 19:11:53
j105,
If I recall right you will need to add more shims to get your travel to go past center.
I maybe stand corrected on this/
Mike
