supper 77 wont charge
denny(ny)
03-31-2006 15:02:02
my super 77 isnt charging. on a previos post, it says the point in regulatin might not be opening. I pulled the cover off with trctor running points are closed. points are closed with tractor off also. Could this be the problem or could genny be shot? How bout a dirt cheap 12v conversion?
J. Schwiebert
03-31-2006 16:54:40
 Re: supper 77 wont charge in reply to denny(ny), 03-31-2006 15:02:02
This must be a gas tractor with a 6 volt system? i am used to diesels and they are 12 volt. No problem. First of all the problem can be in the generator or the regulator so you need to check each one seperately. Do you have a pair of jumper cables and another jumper wire? How about a voltmeter? I sent you an e-mail. I did an article for the hpoca newsletter sometime ago on trouble shooting charging systems with generators and I can send you a copy of that once I get your e-mail. To be honest if that is where you started your trouble shooting methods scare me a little.J.
