Starter Question on S88
jimfitzgerald-ia
03-29-2006 11:21:37
I getting ready to fire a '54 Super 88 Diesel. It has the starter rod that you manually engage. When I push in the starter rod, the bolt that makes contact with the starter switch causes a spark. This this spark normal or is something not right with the starter?
FYI - its original with 12V generator and when it does this, I had the rest of the electrical system unhooked. The battery is connected and the cable to starter from the battery is hooked up, but everything else is unhooked. Any info is appreciated.
jimfitzgerald-ia
03-29-2006 21:17:39
 Re: Starter Question on S88 in reply to jimfitzgerald-ia, 03-29-2006 11:21:37
False alarm. I put all new wiring on the tractor and hooked everything up and now it works.
