Coolant in oil 1600 gas
Tractorcedric
03-27-2006 20:27:33
I have the oilpan off,the timing gear cover off and I hooked my air compressor hose to the fitting were the coolant temp sender screws in. I let the compressor build up to 20 lbs and shut it off. I could not see any leaks around the bottom of the sleeves. Do you think it will have to be hot to show up? Any suggestions will be appreciated. Thanks
