Hydra-Drive Rebuild - Hit a brick wall
Iowa Jim
03-27-2006 12:28:25
Folks:
I tore into the Hydra-Drive from my 1800 yesterday. I have the access cover off and the shaft support bracket. I removed the oil seal (it was SHOT!) but I can not get the next plate off to access the bearing. Can any of you give me some advice on getting the next plate off of the unit?
Jim
Iowa Jim
03-28-2006 17:53:18
 Re: Hydra-Drive Rebuild - Hit a brick wall in reply to Iowa Jim, 03-27-2006 12:28:25
I got it off, just needed some heat and convincing.
Now I can get into it since I received the overhaul kit from O'brien County IMplement.
Jim
Bison
03-27-2006 19:00:40
what you need is a service manual, you will need to know the specs to to do a proper rebuild.. what was the problem to start with anyway.is it a two or three speed?
Iowa Jim
03-28-2006 04:39:22
 Re: Hydra-Drive Rebuild - Hit a brick wall in reply to Bison, 03-27-2006 19:00:40
I have two service manuals, and I & T and an Oliver 1800 1900 Shop Manual!!!
I am servicing the Hydra-Drive since I have the engine completely removed from the tractor and the units seeps oil from botht he input and output shafts.
I did not have time last night to work on the unit, but in my thoughts I beleive the issue is the gasket. The dressing used on the gasket has sealed the two parts together. I will attempt to break the bond tonight.
glr62
03-27-2006 17:47:40
There is an o-ring by the bearing, if this is the rear of trans. Counter shaft will have to be dropped down and moved to side to get everything removed.
