timing
Dave Doman
03-26-2006 11:03:22
Hi I just reassembled a Hercules 1XB3 form a box of parts. Got a crank from Drapers in Wa and new bearings. I seem to have a timing problem. I thought I had the timing marks right but I get very litle compression (40-50 lbs)and it blows out the intake. Anyone any suggestions before I tear it apart again? Thanks Dave
Larry from md
03-27-2006 09:06:35
 Re: timing in reply to Dave Doman, 03-26-2006 11:03:22
You can check the valve action by removeing the side panel and watching them.Remove the plugs and insert a wood dowel.When the wood is comeing up on compression the valves are closed.
RAB
03-26-2006 11:12:28
Are we talking camshaft timing here, or just ignition timing?
Probably 180 degrees out if it is ignition timing, or wrong rotation maybe for plug leads?
A bit more info would be good.
Regards, RAB
Dave Doman
03-26-2006 11:22:25
 Re: timing in reply to RAB, 03-26-2006 11:12:28
Hi I am thinking vavlve timing, the camshaft may not be timed to the crank properly. I seem to have the ingnition ok as #1 fires about the time the flywheel mark shows up at the timing hole back of the engine
dd
RAB
03-26-2006 12:43:15
 Re: timing in reply to Dave Doman, 03-26-2006 11:22:25
Not necessarily. 180 out (on the magneto) will be 360 out on the flywheel.
Regards, RAB
Dave Doman
03-26-2006 14:57:22
 Re: timing in reply to RAB, 03-26-2006 12:43:15
Hi Thanks makes, sense I will look at that. Why would I have no compression and air coming out the intake? regards Dave
