2150 puller problem
paul blinn
03-25-2006 20:11:18
I have changed the pistons to a e6 mack piston and used a jdeere rod.my problem is that the piston is hitting the conter weight on the crank.
Is there another piston that would match these sizes.need help asap.
Oliver puller
03-26-2006 15:45:47
 Re: 2150 puller problem in reply to paul blinn, 03-25-2006 20:11:18
third party image
I don"t have a definite answer for you but I am also building this Oliver 1800 pulling tractor using the 478 hercules. Mine just has the stock bore so far.
I know of a guy that took the sleeves out and ran minneapolis 4 3/4" pistons right in the block. He also used John deere rods. I was going to put John deere 4 3/4 pistons in mine but the with the stock rod, the piston does not come up far enough in the bore. I never got around to experimenting with different rods.
What size are the mack pistons?
Do you have any pictures of your tractor?
A.P.
03-26-2006 03:19:16
Why can't you shorten or notch the piston skirt? How much interference is there?
