Oliver 70 shift pattern
Keith-OR
03-25-2006 17:45:10
I acquired a Oliver 70 RC. found shift pattern on this site as plate is missing, BUT this one has 3 reverses, in the forward H where 2nd is suppose to be is a med speed reverse and in the lower (to the rear) H there are 2 reverses the standard one back from 3rd gear and then there is a HIGH speed reverse straight to the rear from 6th gear.
The only reason for this pattern on this Oliver, is that in the 50's,and early 60's they used these tractors in the pea harvest. Swathers mounted on the rear and they run in reverse,also some Olivers had a side loader chute that would pickup windrowed peas and blow them into trucks that would haul the peas to the "pea viners". They also had tractors with rear mounted loaders that would push the pea vines up to the front of the viners so they could be pitched into the viner with a pitch fork. Forgot all about these reverse running Olivers, too many years ago!!!
5_____ _1 R m_____ 6_____ _3 R h___ R l
Keith & Shawn
