Cockshutt 1755 Diesel
Wade B H
03-25-2006 17:22:59
Engine smokes excessively. Injector repair shop discovered 1 of 6 injectors to be bad. And I noticed that 1 of the 6 exhaust ports had very bright black carbon built up like unburnt fuel had been passing through. Five injectors cleaned with new seals and one new injector reinstalled. Engine still smokes a LOT. And now even back fires occasionally at full throttle. Still starts easy, so thinking compression can't be too bad. Any thoughts?
WFE 2
03-25-2006 19:28:04
 Re: Cockshutt 1755 Diesel in reply to Wade B H, 03-25-2006 17:22:59
This is white smoke, right? Could still be low compression in one cylinder (broken ring/scored cylinder wall, etc.). If you have verified that all nozzles are working and spraying fuel at the appropriate time, a compression check is probably in order, especially if it is now misfiring at higher engine speeds. That is my first thought.
