Oliver 70 steering Problem?
dej(JED)
03-22-2006 12:12:14
Steering wheel turns freely going into the steering box in the dash, but that is it. There is no output from there. Has anyone ever encountered that problem?
john-holcomb
03-22-2006 15:14:49
 Re: Oliver 70 steering Problem? in reply to dej(JED), 03-22-2006 12:12:14
Are the wheels turned all the way in one direction. If the stops are broken on the front gear it is possible to turn the worm right off the sector. Or if someone has had it apart and didn't put it back centered with the wheels centered you could also turn it off the sector.
Buster
03-22-2006 13:03:31
Check the bearings in the gear box, on a 70 I had the inner bearing went bad and let the worm gear on the steering shaft drop down, would'nt steer at all.
