Problem with hydraulics on a White 2-135
Jack U
03-20-2006 09:35:13
I have a 1978 White 2-135 fairly often when you move the hyd. lever forward ahead to retract the cylinder and lower the implement it will not lower so you must come to a stop and move lever back and forth several times until it will lower. Appreciate your help.
IanC
03-20-2006 14:24:20
 Re: Problem with hydraulics on a White 2-135 in reply to Jack U, 03-20-2006 09:35:13
Does it only do it with one set of couplers, or both? Try moving hoses to a different set, and also reversing hoses within a set. It really sounds to me more like worn out couplers than in the valving.
