Oliver 1655 wouldn't disengage
Roland
03-18-2006 18:44:44
When I went to neutral the power from the engine kept turning so I couldn"t shift back into gear so I turned the tractor off, when I started it back up everything worked ok. The 1655 has a over/under Hydraul. And it wasn"t the linkage as I had more clutch travel. Must have been in the Hydraul?? Any adgustment?
Ralph 550
03-20-2006 19:23:26
 Re: Oliver 1655 wouldn't disengage in reply to Roland, 03-18-2006 18:44:44
I have a 1650 gas that did the same thing last summer and I had a new button clutch and presure plate put in. GUESS WHAT THE SAMETHING HAPPEN AGAIN ABOUT 2 WEEKS AGO.
Roland
03-19-2006 07:39:19
It has worked ok maybe 100 times since the problem and I have about an inch more travel on the clutch after it disengages now but it looks a new pressure plate sometime. Thanks to all who replied.
J. Schwiebert
03-19-2006 05:32:23
I think you might have answered your own question or am I not hearing what you said. : more travel"? Is that saying you have more free travel in your petal now? How much free travel do you have? Does the petal have the same amount of firmness? Do you have an organic or a button clutch? Serial number might help if everything is the same as when it was built. Remember the clutch has to disengage before the chain coupler stops. Could be in the pressure plate or even a pilot bearing starting to tie up. Questions?
Spike in WI
03-19-2006 05:23:33
I had the same problem with my 1850. I don't know if the 55 series is the same but there is a grease zerk on the top of the flywheel housing. Give it about 3 or 4 shots with the grease gun and work the clutch back and forth. This may be a simple fix. If that doesn't work you may have bigger problems.
tw
03-18-2006 20:34:01
I had the same problem on a 1650 & the springs on the pressure plate went bad. It felt like stepping on mush when stepping on the clutch pedal. Just got done a couple weeks ago with replacing the clutch & all is much better.
j meyer
03-18-2006 18:55:54
Your post is kinda vague to me- could you repost your problem a bit clearer? Thanks
Roland
03-18-2006 19:57:39
 Re: Oliver 1655 wouldn't disengage in reply to j meyer, 03-18-2006 18:55:54
The chain conector was still turning and the gears would grate so I couldn't shift into gear. Thanks for any help.
Jake in NY
03-18-2006 20:19:16
 Re: Oliver 1655 wouldn't disengage in reply to Roland, 03-18-2006 19:57:39
I'm no expert here, but it sounds like maybe your clutch is bad.
Jake
