help with tire size on 77
jayson
03-16-2006 14:12:21
Replacing all tires and rims on my 77....the only company that I can find that makes the rear rim makes it in a 12 x 38 instead of the original 11 x 38. Will 12.4 x 38 tires look ok on those rims or will they look out of place? Every tire shop has a different opinion, but the most common suggestion I have had is to put 13.6 x 38 tires on it, but I guess that will raise the drawbar height a couple inches. Any input would be appreciated. Can"t wait till this project is over. Thanks
Josh H
03-16-2006 16:14:07
 Re: help with tire size on 77 in reply to jayson, 03-16-2006 14:12:21
I think i would put the 13.6 tires on it, or look in a salvage yard for original rims. I thought the originals were 10" wide but i must be wrong. Usually the tire is the same width as the rim, or one size up. (12.4(11") or 13.6(12") on 11" rim) If the tire is narrower than the rim the sidewalls look kinda pulled out. You see it on pulling tractors a lot, but I don't think it looks real good.
Josh
evielboweviel
03-16-2006 15:18:51
have 12.4x38 on my 66. grandpa had a set put on in 68 I replaced them last fall. probably have narrower rims then you have. like the looks and like the traction. also isn't a 12.4x38 same as the old 11x38??
good luck
Ron
jayson
03-16-2006 15:22:08
 Re: help with tire size on 77 in reply to evielboweviel, 03-16-2006 15:18:51
yes...I guess they are the same but they were on a 11" rim..not 12"...that's why I am concerned.
evielboweviel
03-16-2006 15:27:38
 Re: help with tire size on 77 in reply to jayson, 03-16-2006 15:22:08
ok reread your question and went to millertire.com then to faq's. they say for tractor pulling to use a 12" rim with a 12.4x38 as to looks everybody is different. this will give a flatter look to the tire and equal better traction
good luck
Ron
