Size Plow and 1800A Will Pull
MOSteve
03-16-2006 08:39:31
There is a White 548 8 bottom plow advertised on this site that I'm interested in.... Will my 1800A pull it? It's the 6 cylinder Waukeshau gas engine and is in good shape..... .Thank you.
j meyer
03-17-2006 21:40:11
 Re: Size Plow and 1800A Will Pull in reply to MOSteve, 03-16-2006 08:39:31
As others said, no way will it pull it...like my father says- it will pull it around the yard....LOL. It'll find a good home anyways though. We got an Oliver 588 4X20 plow that our AC 7020 had fits with, but I now believe our 145 White will have more then enough power for it. So hopefully we'll be talking "White Power" on there this fall!!! LOL...looking forward to Getting it done!!!
MOSteve
03-16-2006 16:49:51
Thanks for the advice.....The concensus is no.....You sall aved me the trouble of having to re-sell the thing once I figured out on my own the hard way....
2255tr
03-16-2006 11:59:16
You would need a four wheel drive for that much plow. That 548 White plow has two add on bottoms in the frame.If you were to remove them and shorten it to a 6 bottom 16" or 18" you might be able to pull it shallow in sandy ground. A 5 bottom would be a more ideal match for a gas 1800A
tim coltman
03-16-2006 11:17:53
we have an 8 bottom white plowthat we pull with our 4490 case with the duals on cant tell you the horsepower of the top of my head but it works the snot out of it and its a pretty big tractor. i dont think an 1800 would pull it tim
Josh H
03-16-2006 10:03:29
I think an 1800 is like 70 hp. Around here thats more like 3-4 plows.
Josh
Carlton Grambo
03-16-2006 09:03:08
Your 1800 was only a six plow tractor when new. The plows back in the early to mid sixties were a lot lighter than the more modern plows. So the answer on the the eight bottom White is no. I doubt if the early 1900's could pull it. Could be wrong on the 1900. Good Luck.
