Thanks for the info. What about a Cat 3126?
Rex-Road
03-15-2006 18:53:10
Thanks for the info, guys. It sounds like it'd be lots of trouble to put that engine in an oliver. What about dropping a Cat 3126 in? Would that be worth doing? I'd turn the Cat's fuel pump down a bit to reduce HP. That engine has over 200 HP, I believe. It may even have as much as 250. That many horses would tax the rear end assembly, for sure.
J. Schwiebert
03-15-2006 19:04:57
 Re: Thanks for the info. What about a Cat 3126? in reply to Rex-Road, 03-15-2006 18:53:10
I have a customer who has a fleet of the 3126 Cat engines. He has had problems At what RPM are you getting that horse power. Also make sure those engines have all the up dates and make sure you get all the controls for the electronics. That engine would not make my list for what you are doing. Around here you would be better off keeping your money, add a little from the bank and get a newer tractor.
Rex-Road
03-15-2006 23:43:52
 Thanks, J. in reply to J. Schwiebert, 03-15-2006 19:04:57
thanks, J. I'll probably look into getting a 'normal' Perkins from an 1850 or so.
