The 105 has the clip on type fuel filter right? No lift pump, just goes straight to the injection pump? turn off the fuel on the tank, remove the old filter and put the new one on. Once on, tunr the fuel back on and there is a bleeder on top of the filter housing. The pressure inside the tank will push it through the filter. Works best w/ a full tank. That's all I have to do w/ our 1855, can do it in less than 5 minutes. It may not hurt to crack the line to the injection pump after bleeding the filter. Our 1855 is fine w/ just bleeding the filter. Our Massey 285 (perkins 318) needs to be bleed up to the pump. The hydraulics are another story. You need (3) 5 gallon pails to catch the oil in, remove the plug in the middle on the bottom of the filter housing. Once it's done draining, you need to grab onto the cast hex part w/ a big wrench and turn it off. Sometimes it takes a lot of ooooo mph to get the filter loose. Pay attention to the way the gaskets are located w/ the old filter, theres quite a few in there, I think 5. There is one that sticks to the top of the housing, dig that one out and install the new one. If I missed anything, J Schweibert and the other guys can set me straight, but it should be almost the same as servicing our 1855 as far as general filters go. Donovan from Wisconsin
