OC4 final drive drain plug?
henryjr
03-13-2006 17:00:29
Where is it? I can't find the drain plug for the final drive(s). I've found the filler plug (one of the bolts in the final drive bearing cap behind the sprocket.)
Can you help?
RAB
03-14-2006 15:18:49
 Re: OC4 final drive drain plug? in reply to henryjr, 03-13-2006 17:00:29
Level plug and drain plug are similar. level plug is near the bottom of those housings and the drain plug is at the bottom. You will need both unlesss you aim to fill just the right amount of oil.
RAB
henryjr
03-20-2006 08:16:37
 Re: OC4 final drive drain plug? in reply to RAB, 03-14-2006 15:18:49
Anybody? I"m still stuck. I really, really don"t want to remove the track if I don"t have to.
henryjr
03-14-2006 15:43:43
Found the fill plug. It"s actually close to the top. I can"t find the drain. I removed the bottom bolt, but it is just a cover bolt. I"ve looked on the inside and out. Do I have to remove the track and sprocket to find it?
