88 BELLHOUSING
SCOTTY IN KY
03-13-2006 11:09:14
I went to an antique tractor pull two weeks ago and got the fever to finish restoring my 88 diesel. I"ve got the engine out and was trying to get the bellhousing out of the frame to clean up and paint. I disconnected the pto coupler but the splines on it won"t pull through the bellhousing. The housing hits the motor mount area in the frame before it clears the trans input shaft. I know you guys know all the tricks and I appreciate any info.Thanks in advance,this is the neatest forum on the web!
Tramway Guy
03-13-2006 12:39:32
 Re: 88 BELLHOUSING in reply to SCOTTY IN KY, 03-13-2006 11:09:14
Did you remember to pull the PTO drive shaft out from the rear of the tractor first?
