550 with a few problems
Mike O'Brien
03-12-2006 16:32:45
about a month ago i purchased a 550 that had a few running problems (rusty gas tank, ignition system shot, etc.) after a few weeks of tweaking on it, coating the tank, installing an electronic ignition kit, and polarizing the generator for a neg. ground system, i finally got it going. After a few hours of light grading with a 6' blade, i noticed a few things.
1. fluid leaking out of inspection plate at bottom of trans. i pulled the plate and a rusty, watery, oily fluid came out, about a quart. the only thing i can guess is that this is trans/gear oil leaking through the shaft seal into the clutch area. does this make sense?
2. overheating. the first day i drove it for a few hours with no overheating problems, but i noticed a small bit of coolant coming out of the overflow hose. today, i got on it and began working the blade. after seeing the overflow hose pumping out a good amount of fluid, i drove back to the shed and shut it down. is it overheating? or should i try and find an overflow bottle/new radiator cap?
thanks for the help, this forum has been very helpful.
J. Mash
03-13-2006 20:18:31
 Re: 550 with a few problems in reply to Mike O'Brien, 03-12-2006 16:32:45
Yes I agree with what he fellas said. I have one of those ignitions on my 550 and it does change the timing a little. I ended up timing mine by ear. I really like those ignition systems.
JD in da
03-13-2006 05:27:36
Your coolant may have just been overfilled. If temperature gauge is working it will show overheating. It's now running warmer and coolant is expanding as it really heats up. I can't think of any place my super 55 didn't leak trans lube. Probably wait to split tractor to fix seals until pto becomes a problem.
John
Mike O'Brien
03-12-2006 16:37:17
forgot to mention, it diesels when i shut it off, could possibly be the timing. i trusted the timing setting from the previous owner..
thanks
Don-Wi
03-12-2006 21:27:41
 Re: 550 with a few problems in reply to Mike O'Brien, 03-12-2006 16:37:17
If the timeing is off a little, it could run hot and deisel when you shut it down. My 1600 did when I first got it running, but after playing with the distributer I got it to run great. You said you installed a new electronic ignition? I've heard a few say that the timeing is different when you install one of these, but I have no experience w/ updating the system. I also can't say what the fluid is, but it sounds feasible.
Donovann from Wisconsin
Mike O'Brien
03-14-2006 15:56:27
 Re: 550 with a few problems in reply to Don-Wi, 03-12-2006 21:27:41
thanks for all of the responses. it seems you confirmed my suspicions... the last paint job kinda glued the distributor in place, so i figured it'd be ok running the way it was, but i'll be a good boy and time it right...
mike o'brien
