Oliver 77 lighten up??
T.r.y.
03-12-2006 10:07:31
I would like to take the pto unit and the hydraulic unit off my tractor. Whats all envolved?? I had the pto out when I rebuilt motor? thanks
evielboweviel
03-12-2006 15:33:58
 Re: Oliver 77 lighten up?? in reply to T.r.y., 03-12-2006 10:07:31
pull the pto out and remove the complete hydraulic unit from top of trans then pay somebody 150-200 for a smooth top for the tran or gut everything you can out of the hydraulic top and use it.
Ron
t.r.y.
03-12-2006 17:36:21
 Re: Oliver 77 lighten up?? in reply to evielboweviel, 03-12-2006 15:33:58
I can make the smooth top but doesn't the shifter and the forks asymble on the unit plate some how.?? Or do you actually just take the hydro. unit off the the shifter plate seperatly?? thanks
Jak
03-14-2006 10:49:02
 Re: Oliver 77 lighten up?? in reply to t.r.y., 03-12-2006 17:36:21
Just did this to mine.Its easy to do and the original aluminum cover isn't too heavy so I left mine on.I took all the bolts,valve assemblies and levers out and am going to make a plexi glass cover to put on.Took the live pto out too.Should help a little,the pto was kinda heavy.Jack(TN).
t.r.y.
03-14-2006 17:37:27
 Re: Oliver 77 lighten up?? in reply to Jak, 03-14-2006 10:49:02
thanks for the info. last year i did great in the 4500 class I would like to try 3750 4000 4500 and 5500 this year. thanks again Trent
Jak
03-15-2006 04:48:44
 Re: Oliver 77 lighten up?? in reply to t.r.y., 03-14-2006 17:37:27
I like to get in 4500 open,she will go third gear there.
