my 2-85 white threepoint won't move
oliver nut
03-12-2006 09:16:09
my 2-85 white three point won't move after changing the oil filter and hydralic lines? everthing else works
Larry from md
03-13-2006 08:58:13
 Re: my 2-85 white threepoint won't move in reply to oliver nut, 03-12-2006 09:16:09
Did you reconect the external linkage on the left side.It often gets unhooked so there is more room to turn the hose ends.
Calvin Eyer
03-15-2006 06:04:58
 Re: my 2-85 white threepoint won't move in reply to Larry from md, 03-13-2006 08:58:13
yes i did remove linkage. going to check out. thanks
730virgil
03-12-2006 15:24:51
sounds crazy is it possible to put lines together backwards ?
Calvin Eyer
03-12-2006 16:27:12
 Re: my 2-85 white threepoint won't move in reply to 730virgil, 03-12-2006 15:24:51
730 virgil hydraulic lines that were replaced were of differrent,1 was a largr hose coming up from the pump. the other one was a small power steering line.now what?
